Forum >DFRobot TEL0138 GPS Receiver. Windows 10
userHead Derek.Johnstone 2024-06-12 02:30:05 883 Views5 Replies
HI
Does the DFRobot TEL0138 GPS Receiver work on Windows 10, feeding a stream onto a COM port?
I have had trouble with a similar device, where the drivers were withdrawn in 2012. Only usable on Windows XP.
Thanks for your help.
2024-06-23 01:21:29
I'm please to tell everyone that the TEL0138 GPS Receiver works on Windows 10.
On my laptop it was found as COM3
Microsoft Autoroute 2013 now know where I am.
Regards derek
userHeadPic Derek.Johnstone
Alex.Just-Alex wrote:
Hi Derek,
that is exactly what I needed to know and couldn't find an answer anywhere. I need a GPS that I can access via serial coms. I thought I might have to buy one on spec just to find out until I found your post.  I signed up here just so I could say thank you.
Alex
2024-08-12 23:40:01
2024-06-12 05:47:50
This wiki page shows that you need to install google earth in windows to use it.
https://wiki.dfrobot.com/USB_GPS_Receiver_SKU_TEL0137#target_4
userHeadPic lia.ifat
Derek.Johnstone wrote:
That's not what I want to do.
I have old Microsoft Autoroute 2013 on my laptop, that takes a serial feed from a COM port.
I use that because I can import a file of 40 OS Map references, and Autoroute plots a route to visit all references.
I have a Fortunea U2 GPS receiver, that used to work OK when it was on XP, but there were never any Windows drivers for it on Win 7 onwards.
So what do you think?
Regards  Derek
2024-06-13 08:11:38
Just wanted to add a clarification here.
You do not NEED to install google earth in order to use it.
It is clear from Derek's second post that the GPS operates as a serial com device and can be used by any software that uses serial communication - google earth is simply one option.
2024-08-12 23:43:13
