Forum >SEN0204 NPN Version
General Gravity
SEN0204 NPN Version
userHead cwills 2024-06-11 08:04:26 515 Views2 Replies
Is there an NPN version of this sensor?  I need to have an active output when the water level drops below the sensor rather than above, similar to the SEN0368 in the negative direction.  Since this is intended for an existing design I cannot use an inverter on the output.  The SEN0368 seems to be rather ESD sensitive and is not reliable for this reason.
2024-06-12 06:07:50
If needed, you can make a water level indicator by yourself like this: https://www.theengineeringprojects.com/2022/02/water-level-indicator-using-arduino.html
userHeadPic lia.ifat
2024-06-12 06:06:18
The SEN0204 water level sensor by DFRobot is typically designed with PNP output. Unfortunately, there doesn't seem to be a direct NPN version of the SEN0204 available from DFRobot.
