Forum >Analog Water Pressure Sensor [SEN0257] Waterproof level
General Gravity
userHead Christoph.Rademacher 2024-06-14 03:18:40 885 Views3 Replies
Im building a precise fill level meter for our camper vans freshwater using this sensor. Now I was wondering, if the whole sensor (including the side where the cable goes in) is waterproof or just the threaded side. So could you just drop the sensor into a watertank or does it have to be attached using a thread from the outside?
2024-06-14 04:27:29
The 3-pin connector is not waterproof. The black insulated part is.
userHeadPic lia.ifat
Christoph.Rademacher wrote:
Thank you. Thats what i hoped for and it makes things a bit easier…
2024-06-14 23:27:27
