Forum >Huskylens flipped camera on screen
userHead Mr G 2024-06-16 03:07:47 1417 Views4 Replies
Hi, I recently bought 20pcs of huskylens for a project for my client. I need to replace the onboard camera with another camera with a longer FFP cable because I need to mount the camera on a seperate place. But now the image of the camera on screen is flipped 180deg vertically. Is it possible to get a firmware from your side so the screen can be flipped or is there a code that i can use in arduino to flip the screen in my code. I understand this will void the warranty but I will take all the responsibilities.
G
2025-01-15 09:38:31
any update on this? is it possible to flip the view?
userHeadPic Adhvik
2024-06-17 04:29:49
Sorry but I can't find the code in the wiki or e Arduino GitHub for husky to flip e image on e husky screen. Can you kindly point me to the link or send me which code I can use.
G
userHeadPic Mr G
2024-06-16 07:23:57
If you prefer not to modify the firmware directly, you can use Arduino code to flip the image.
userHeadPic lia.ifat
G
2024-06-17 04:30:28
