Forum >SEN0405: Accelerometer data at 100Hz
userHead Nicolas_1410 2024-06-27 01:29:10 575 Views2 Replies
I try to retrieve data using a SEN0405 accelerometer on a raspberry Pi4.
Using examples, I manage to get data, but at a low rate. However, I do configure it with the appropirate rate.
I tried several power modes.
Data are recorded in a file with timestamping. There is no consistency in time and only 10-12 data per seconds.
How is it possible to get data at a real rate of 100Hz, with a timestamping incrementing 10ms.
Thanks, any help with this issue would be greatly appreciated
2024-07-18 05:41:22
I also use chatGPT with no success
Solution is to go with C.
Python is way too slow to manage register reading efficiently. With C, I can go to the max sampling freq easily
The ST C exemples are very great
https://github.com/STMicroelectronics/STMems_Standard_C_drivers/blob/master/lis2dw12_STdC/examples/lis2dw12_read_fifo.c
userHeadPic Nicolas_1410
