Forum >3.7V Li Battery Fuel Gauge not showing correct charging voltages
TroubleshootingGravity
userHead Muhammad Faizan.Khan 2024-06-27 02:33:30 284 Views1 Replies
Hey, hope you all are fine.
there is an issue with an 3.7V Li Battery Fuel Gauge that when i remove a power supply from the connector it is giving me exact voltages of a battery and percentage but when i connect a power supply with the green connector for charging, its giving me more voltages than the actual voltage of a battery. i want an exact charging voltages and percentage.
