Forum >FireBeetle 2 ESP32-C6 charging LED
Troubleshooting
userHead vegos 2024-06-29 03:29:44 746 Views4 Replies
Hello.
One question, does the charging LED lights when connected to battery and solar panel?
I measure 5V from the panel (connected to VIN), and about 3.6V on the battery (I guess I should have more that 3.6 if it was charging).
Charging LED does not light, unless I connect the board with USB.
Thanks,
Antonis.
2024-07-07 09:57:23
Looks like the charge is full.
userHeadPic lia.ifat
2024-07-06 12:22:54
Thanks for the info.
I guess that the current supplied from the solar panel is not enough, will try to measure it tomorrow.
userHeadPic vegos
