Forum >Servo controlled by DFR0548 constantly spinning.
Troubleshooting
userHead Random-person 2024-07-03 16:32:45 619 Views5 Replies
Hello, I'm using DFR0548, with a servo. When it is told to move to move, instead of heading to a certain angle, it constantly rotates at a differing speed depending on the angle. Is there any ideas to the cause of this and how to fix it?
2024-07-09 23:53:37
When you have the appropriate person by your side, you won't need that other 80 percent of the time. This place, <a href="https://poppyplaygame.io/">poppy playtime</a> is where I was able to find the joy I was looking for. They were able to tell me the answer, which has made it possible for me to have delight each day, despite the long and difficult hours I spend at work.
userHeadPic Patrick.Howard
2024-07-06 07:34:41
Continuous rotation does not have a position sensor, which is not able to do positioning.  If you need position control, you can add one rotation sensor on your own.
userHeadPic R2D2C3PO
Random-person wrote:
How would you go about that?
2024-07-07 19:34:08
2024-07-04 00:06:50
Make sure you are using a standard positional servo and not a continuous rotation servo.
userHeadPic lia.ifat
Ah, yeah, that'd do it. Is there any methods to work around that or to more easily control a continuous rotation servo?
2024-07-05 15:10:34
