Forum >SEN0539-EN turn off voice responses
General Gravity
userHead chandrian317 2024-08-14 08:24:28 1259 Views4 Replies
Is it possible to turn off the voice responses for this module?
2024-12-09 10:47:04
Dial the code to the SPK2 side, at the same time SPK2 interface do not external speakers will not have voice prompts.
userHeadPic yiqing.guan
2024-12-08 08:02:43
use the mute function ==   set_mute_mode(1) with i2c connection and  similar with uart/serial   setting_CMD( 0x83, 1) ==  that will also shorted the dead time.
Just switching the speaker to external, will block the mic input until the response phrase is finished.
userHeadPic karl.wachs
2024-11-16 08:43:50
The API has a command to setMuteMode
userHeadPic bradjshannon
2024-08-27 07:29:42
Hi, apparently if you don't have a speaker connected to speaker 2 then putting the switch in that position makes it quiet.  If you do have a speaker 2 connected then I'm sorry, someone more experienced will have to advise.
userHeadPic Mike.Shepherd
