Forum >SEN0257 Fluctuating voltage
TroubleshootingGravity
userHead Rocco 2024-09-06 06:00:06 535 Views0 Replies
My tank is 9 meters on top of the house , Sensor is connected on the ground .
When i calibrate the sensor the output is very stable.
The more water in the tank the higher the voltage fluctuation.
It fluctuates between 0.5 and 0.7 volts, so i get empty tank and then while its filling it wil jump from below 10% to 80% .
I wrote an program for arduino to take 100 samples and then show percent and send to home-assistant also show on 16x2 display.
With 100 samples tank shows full most of the time and just before  empty it will drop to showing below 10%
