Forum >Are there compatible OV2640 cameras with longer leads or different lens for the HUSKYLENS?
General HUSKYLENS
userHead alfredcrabtree 2024-09-06 06:30:06 742 Views2 Replies
I would like to free the camera from the board and use a longer lead to connect a different camera. I see OV2640 cameras with long leads, but they all say ESP32 compatible.  I am unsure if that work with HUSKYLENS. I need to control minimum focus distance, and or the working distance, so an adjustable lens on an OV2640 camera with a 120mm lead would be ideal. I am unsure what would be a good purchase for this application, any help would be appreciate. Ideally, I would be able to frame an image of a flat surface 60x60mm from a distance of 60mm or less. I intend to play with the onboard camera, but my understanding it has a 40cm minimum focus distance?
2024-09-12 05:06:31
You can refer to this OV2640 pinout diagram to replace the camera with the same pinout.
userHeadPic Yeez_B
alfredcrabtree wrote:
Thank you that is helpful
2024-09-27 04:49:08
