Forum >touch screen problems with DFR0550 with raspberry 3B+
userHead TERMISOUND 2024-09-06 22:18:34 646 Views2 Replies
I bought some DFR0550 displays to use with Raspberry 3B+ at start the touch screen does not work properly and the display turns off for a moment and turns on again randomly.
Also the pages change autonomously as if there were touches.
Can you suggest me some solutions?
Thanks and regards
2024-09-10 00:03:50
I tried with a 10A lab power supply but nothing changed.
userHeadPic TERMISOUND
2024-09-09 17:46:22
Are you able to power the Pi 3b+ with an adapter of a higher current specification?
If the power supply is insufficient, the touch function may not work properly.
userHeadPic Yeez_B
