Forum >Turbidity Sensor SEN0189
TroubleshootingGravity
userHead Alief.Fadhal Handoko 2024-09-06 18:16:03 751 Views1 Replies
Why is my LED connected to the Dout always on, even when I'm using an analog switch? Also, why is the voltage output from my sensor not as expected?
2024-09-09 17:44:35
Even in analog mode, the Dout detection does not stop because the on-board ah-switch only controls whether the OUT pin is connected to Aout or Dout. so when the turbidity of the test solution reaches the threshold, the Dout light will still be on.
You can try to adjust the knob on the adapter board with a screwdriver to see if the light goes off.
Also, are you able to check if the voltage output is now normal when your adapter board and probe have the same wiring sequence as below?
userHeadPic Yeez_B
