Forum >non contact liquid level sensor SEN0204
userHead Alex.Ragas 2024-09-25 02:10:56 593 Views1 Replies
Hi Team
I am looking to use this sensor for a low coolant sensor/alarm on my car, problem is I can't get the sensor output wire to activate a 12v buzzer or a 12v relay as I would also need to switch the output as it's positive when it detects liquid & zero when liquid is not present. is it possible with this sensor or is there another sensor that would be better to use
here is the address of the buzzer I'm trying to use
https://www.jaycar.com.au/mini-buzzer-5-15vdc/p/AB3452
Cheers Alex
2024-09-25 03:04:09
Me again, so a quick google & found out I was wiring incorrectly, now all sorted & will work a treat
userHeadPic Alex.Ragas
