Forum >DFR0760 Speech Synthesizer question - Steps for use with Agon Light 2 single board computer?
General Gravity
userHead Tim.Gilmore 2024-09-25 06:42:21 583 Views0 Replies
I have purchased a couple of these text to speech synthesizer modules and well versed in UART and I2C communication (3.3vdc) in eZ80 assembly and BBC Basic/Assembly for an Agon Light 2 single board computer. All I found was Arduino and Raspberry Pi library's for using them which I am not using either. Can some one fill in the blanks on how to implement this module let's say for I2C that is NOT using an Arduino or Raspberry Pi ?
1. Open the i2c bus as a master - assuming $40 as the i2c address in hex
2. Write a block of bytes to the i2c bus
Do I just write out bytes ($48, $69 - ie Hi) or strings (i.e. “Hello”)?
Do I have to send out a [text control identifier] before I send out the bytes / strings ?
What else am I missing or not doing right here?
3. Close the i2c bus
