Forum >Gravity PH sensor v2 interfaced with Heltec LoRa32 v3
General Gravity
userHead alex.lindon 2024-10-01 02:58:40 517 Views0 Replies
I need help with my Gravity PH sensor. The problem i'm facing is that i only get ph value of 6 to 7 even when i put the probe into a ph 4 buffer solution. I've done the calibration but its not doing anything, it says buffer solution 7 even though its 4. Please help, i'm super new to this
this is the pin connection
VCC - 5.v
gnd - gnd
data pin - GPIO 2
and these are my code
#include "DFRobot_ESP_PH.h"
#include "EEPROM.h"
DFRobot_ESP_PH ph;
#define ESPADC 4096.0   // the esp Analog Digital Conversion value
#define ESPVOLTAGE 3300 // the esp voltage supply value
#define PH_PIN 2        // the esp gpio data pin number
float voltage, phValue;
const float fixedTemperature = 25.0; // constant temperature for pH calculation
  Serial.begin(115200);
  EEPROM.begin(32); // needed to permit storage of calibration value in eeprom
  ph.begin();
  // Calibration configuration
  ph.calibration(0.78, 7.0);  // voltage value for pH 7 solution
  ph.calibration(1.036, 4.0); // voltage value for pH 4 solution
  static unsigned long timepoint = millis();
  if (millis() - timepoint > 1000U) // time interval: 1s
    // Read raw analog value from the pH sensor
    int rawPinValue = analogRead(PH_PIN);
    Serial.print("Raw Pin Value: ");
    Serial.println(rawPinValue);
    // Convert raw pin value to voltage
    voltage = rawPinValue / ESPADC * ESPVOLTAGE;
    Serial.print("Voltage: ");
    Serial.println(voltage, 4);
    // Convert voltage to pH value with a fixed temperature
    phValue = ph.readPH(voltage, fixedTemperature);
    Serial.print("pH: ");
    Serial.println(phValue, 4);
  delay(2000); // Delay for 2 seconds (2000 milliseconds)
