Forum >Bluno Bee TEL0073 HID problems
TroubleshootingBluno
userHead Josh.Harle 2024-10-05 00:31:05 767 Views1 Replies
Hi All,
I'm finding the documentation of the HID functions of the Bluno Bee quite difficult.  For one, when the thing is in HID mode, I can't pair with it: I'm getting an error that it can't pair due to issue with PIN (it doesn't ask for a pin in this mode).
Also, for sending key presses, does anyone have a sketch example of this?  Is it characters, hex code, ascii code??
Thanks for the help
Josh
2024-10-23 17:01:34
After our testing, there is a bug in the HID of the current firmware of this module, and we are sorry that there is no way to fix this bug due to the underlying technical reasons.
We recommend that you try using firmware version 1.9 or 1.8 to use the HID function.
Firmware link:
https://wiki.dfrobot.com/Bluno_SKU_DFR0267#target_8
userHeadPic Yeez_B
