Forum >MCP23017 withrotary encoder on a Arduino Leonardo
ArduinoTroubleshooting
userHead Sean.Haynes 2024-10-14 04:45:51 657 Views0 Replies
Good afternoon all
I purchased a MCP23017  expansion card for my Arduino Leonardo board. the board is connected to the Leonardo using the supplied ribbon connected to the SDA / Pin 2 , SCL /Pin 3, Gnd and 5v.
I have a PEC11 rotary encoder which has 5 pins, 2 for the intergrated switch which works fine and 3 for the endcoder, 2 signal and one Gnd. I tried, very hard to understand the sketch here, but clearly I have done something wrong…..
https://github.com/DFRobot/DFRobot_MCP23017/blob/master/examples/ioInterrupt/ioInterrupt.ino
The objective is to be able to assign a rotary rotation to  specific buttons in a joystick library. Witin the code is a print function so it should print out a ‘CCW’ or ‘CW’ statement in the serial monitor interface as the rotary encoder is rotated. It will only print the ‘CCW’ statement - constantly, not just when turned? I have of course checked the wiring, but after playing with this for some time and having limited knowledge I was hoping someone could point me in the right direction. Many thanks.
#include <Joystick.h>
#include <Rotary.h>
#include <elapsedMillis.h>
#include <DFRobot_MCP23017.h>
DFRobot_MCP23017 mcp(Wire, 0x20);
bool intFlagA = false;  //INTA interrupt sign
bool intFlagB = false;  //INTB interrupt sign
#define Collective A0
int xAxisRotation_ = 90;
#define Throttle A1
int Throttle_ = 0;
#define Button1 1
#define Button2 4
#define Button3 5
#define Button4 6
#define Button5 7
#define Button6 8
#define Button7 mcp.eGPB0  //Encoder1 Button
//#define Button8 mcp.eGPB1  //Encoder2 Button
#define Button9 mcp.eGPA0   // Encoder CW
#define Button10 mcp.eGPB7  // Encoder CCW
elapsedMillis timeElapsed;
unsigned int t_interval = 200;   //interval to hold buttons on for when needed
unsigned int enc_interval = 50;  //interval for encoders
Rotary ROTARY1 = Rotary(mcp.eGPA0, mcp.eGPB7);
int lastButton1State = 0;
int lastButton2State = 0;
int lastButton3State = 0;
int lastButton4State = 0;
int lastButton5State = 0;
int lastButton6State = 0;
int lastButton7State = 0;
int lastButton8State = 0;
int lastButton9State = 0;
int lastButton10State = 0;
int counter = 0;
Joystick_ Joystick(0x04, JOYSTICK_TYPE_JOYSTICK,
                   12, 0,  // Button Count, Hat Switch Count
                   false, false, false,  // X and Y, Z Axis
                   true, false, false,  //  Rx, Ry, or Rz
                   false, true,  //  rudder, throttle
                   false, false, false);  // accelerator, brake, or steering
const bool initAutoSendState = true;
  Joystick.begin();
  mcp.begin();
  ROTARY1.begin();
  pinMode(Button1, INPUT_PULLUP);
  pinMode(Button2, INPUT_PULLUP);
  pinMode(Button3, INPUT_PULLUP);
  pinMode(Button4, INPUT_PULLUP);
  pinMode(Button5, INPUT_PULLUP);
  pinMode(Button6, INPUT_PULLUP);
  mcp.pinMode(mcp.eGPB0, INPUT_PULLUP);
  mcp.pinMode(mcp.eGPB1, INPUT_PULLUP);
  pinMode(SDA, INPUT);  //Leonardo external interrupt 2
  pinMode(SCL, INPUT);  //Leonardo external interrupt 3
  Serial.begin(9600);
  mcp.pinModeInterrupt(mcp.eGPA0, mcp.eHighLevel, gpa0CB);
  mcp.pinModeInterrupt(mcp.eGPB7, mcp.eChangeLevel, gpb7CB);
  attachInterrupt(/*Interrupt NO*/ 0, notifyA, RISING);  //Enable external interrupt 0, connect INTA to the main-controller's digital pin: UNO(2),Mega2560(2),Leonardo(3),microbit(P0)
  attachInterrupt(/*Interrupt NO*/ 1, notifyB, RISING);  //Enable external interrupt 1, connect INTB to the main-controller's digital pin: UNO(3),Mega2560(3),Leonardo(2),microbit(P1)
void gpa0CB(int index) {
  String description = mcp.pinDescription(index);
  Serial.print(description);
  Serial.println(" Interruption CW!");
void gpb7CB(int index) {
  Serial.println(" Interruption CCW!");
/*Interrupt service function*/
void notifyA() {
  intFlagA = true;
void notifyB() {
  intFlagB = true;
  if (intFlagA) {
    intFlagA = false;
    /*pollInterrupts function is used to poll if an interrupt occurs on a port group
    parameter group, the available parameter is shown below: (default value: eGPIOALL):
     eGPIOA        eGPIOB         eGPIOALL
     Port groupA  Port groupB   Port groupA+B
    mcp.pollInterrupts(/*group = */ mcp.eGPIOA);
  if (intFlagB) {
    intFlagB = false;
    mcp.pollInterrupts(/*group = */ mcp.eGPIOB);
  Throttle_ = analogRead(A0) / 04;
  Throttle_ = map(Throttle_, 0, 255, 255, 0);
  Joystick.setThrottle(Throttle_);
  xAxisRotation_ = analogRead(A1);
  xAxisRotation_ = map(xAxisRotation_, 0, 1023, 0, 255);
  Joystick.setRxAxis(xAxisRotation_);
  int currentButton1State = !digitalRead(Button1);
  if (currentButton1State != lastButton1State) {
    Joystick.setButton(0, currentButton1State);
    lastButton1State = currentButton1State;
  int currentButton2State = !digitalRead(Button2);
  if (currentButton2State != lastButton2State) {
    Joystick.setButton(1, currentButton2State);
    lastButton2State = currentButton2State;
  int currentButton3State = !digitalRead(Button3);
  if (currentButton3State != lastButton3State) {
    Joystick.setButton(2, currentButton3State);
    lastButton3State = currentButton3State;
  int currentButton4State = !digitalRead(Button4);
  if (currentButton4State != lastButton4State) {
    Joystick.setButton(3, currentButton4State);
    lastButton4State = currentButton4State;
  int currentButton5State = !digitalRead(Button5);
  if (currentButton5State != lastButton5State) {
    Joystick.setButton(4, currentButton5State);
    lastButton5State = currentButton5State;
  int currentButton6State = !digitalRead(Button6);
  if (currentButton6State != lastButton6State) {
    Joystick.setButton(5, currentButton6State);
    lastButton6State = currentButton6State;
  int currentButton7State = !mcp.digitalRead(Button7);
  if (currentButton7State != lastButton7State) {
    Joystick.setButton(6, currentButton7State);
    lastButton7State = currentButton7State;
  int currentButton8State = !mcp.digitalRead(Button8);
  if (currentButton8State != lastButton8State) {
    Joystick.setButton(7, currentButton8State);
    lastButton8State = currentButton8State;
  if (timeElapsed > enc_interval) {
    Joystick.setButton(9, 0);
    Joystick.setButton(10, 0);
  Joystick.sendState();
void rotate() {
  // HANDLE ENCODER 1
  unsigned char result1 = ROTARY1.process();
  if (result1 == DIR_CW) {
    timeElapsed = 0;
    Joystick.setButton(9, 1);
  } else if (result1 == DIR_CCW) {
    timeElapsed = 0;
    Joystick.setButton(10, 1);
    //delay(100);
