Forum > Voice Recognition DF2301Q using I2C
userHead John.Parnum 2024-10-14 08:55:51 1920 Views1 Replies
I am using the Voice Recognition DF2301Q with I2C and Arduino.  Essentially I am using the DF Robot example program.
My problem is that the void loop freezes after a time and the program stops running.  This time before it freezes is not consistent.  I wonder if this is something to do with the I2C interface.
Anyone else has similar problem ?  Anyone got a fix ?  Thanks John
2025-02-04 23:49:42
Hi, I've ran into a similar issue, did you have any luck finding a solution?
userHeadPic Jill.Stirling
