Forum > SEN0192
General Gravity
SEN0192
userHead Hans-Georg.Schirmer 2024-10-31 20:02:43 621 Views1 Replies
A common question: Is it possible to use the output of the of a microwave sensor (for example SEN0192) with a simple 1/0 or on/off statement (for an alarm purpose)? I mean, without connecting an Arduino etc.?
2024-10-31 23:16:31
It is possible to use the output of a microwave sensor like the SEN0192 to create a simple on/off (1/0) signal for alarm purposes without the need for a microcontroller like an Arduino. You can connect the digital output pin directly to an alarm system, relay, or another triggering mechanism. You can use a 555 timer IC to create a simple alarm system based on the output of a microwave sensor like the SEN0192.
https://www.theengineeringprojects.com/2017/08/introduction-to-ne555.html
userHeadPic lia.ifat
