Forum >MLX90614DCI sensor address change
userHead Will.Chesson 2024-11-12 23:31:11 858 Views2 Replies
Hello, I'm playing around with an MLX90614DCI IR thermometer sensor for a project I wish to do which evolves brake temperature monitoring.
I've gotten one sensor to work just fine, I'm now attempting to incorporate a second sensor with the longer term plan of using four sensors in total.
From what I can understand I need to change the default address of 5a for the different sensors to be seen individually, but I'm having trouble finding out a way to do it with only a couple of examples on the net.
I just wondered if any of you folks know how to or had done it before?
Thank you.
2024-11-15 18:40:03
DFRobot library has the corresponding function:
https://github.com/DFRobot/DFRobot_MLX90614
userHeadPic Yeez_B
Will.Chesson wrote:
That's great, I don't suppose there's an example script is there, as I normally work in python and don't have any experience with c++
2024-12-13 18:25:47
