Forum >Gravity: Analog Water Pressure Sensor Unstable value
TroubleshootingGravity
userHead raza rahil.hussain 2024-11-13 18:19:38 802 Views5 Replies
I'm using Gravity: Analog Water Pressure Sensor with Xiao ESP32C6. I've connected ADS1115 16-Bit ADC in between pressure sensor and esp32.
However, I'm not able to get stable value.
First I run in an empty tank, and it shows the voltage of 0.485.
Now I've filled the tank with 80% water but still it shows 0.496 to 0.498 and sometimes it drops to 0.474.
I've put the drain the pipe at the bottom of the tank and put the sensor there.
Tank height is around 23 inch.
My code is in the below as well in attachment.
#define BLYNK_TEMPLATE_ID "id"
#define BLYNK_TEMPLATE_NAME "Water Level"
#include <Wire.h>
#include <Adafruit_ADS1X15.h>
#include "Ultrasonic.h"
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "key";
char ssid[] = "Creed Family";
char pass[] = "password";
// Define pins and constants
//#define TANK_HEIGHT_CM 58.42  // Tank height in cm (23 inches)
const float OffSet = 0.485;  // Calibration offset for the pressure sensor
// Pressure sensor calibration (in KPa)
float emptyTankPressure = 0.4;  // Pressure at empty tank in KPa
float fullTankPressure = 5.72; // Pressure at full tank in KPa (example value)
// Ultrasonic calibration (in cm)
float emptyTankDistance = 58.42;
float fullTankDistance = 10.0;
// Initialize components
Adafruit_ADS1115 ads;
Ultrasonic ultrasonic(0);  // Ultrasonic sensor connected to pin 0
  Serial.begin(115200);
  Wire.begin();
  ads.begin();  // Initialize ADS1115
  Blynk.begin(auth, ssid, pass);
  Serial.println("/** Water pressure and level monitoring system **/");
  // Initial delay to let sensors stabilize
  delay(1000);
  Blynk.run();
  int16_t pressureValue = ads.readADC_SingleEnded(0);
  float pressureVoltage = pressureValue * 0.1875 / 1000;  // Convert to voltage (assumes FSR ±6.144V)
  float pressureKPa = (pressureVoltage - OffSet) * 250;  // Calculate water pressure in KPa
  // Calculate water level percentage based on pressure data
  float pressureLevelPercentage = ((pressureKPa - emptyTankPressure) / (fullTankPressure - emptyTankPressure)) * 100.0;
  if (pressureLevelPercentage < 0) pressureLevelPercentage = 0;
  if (pressureLevelPercentage > 100) pressureLevelPercentage = 100;
  // Read ultrasonic distance
  long distanceCm = ultrasonic.MeasureInCentimeters();
  delay(1000);
  //float waterLevel = TANK_HEIGHT_CM - distanceCm;  // Calculate water level in cm
  // Calculate water level percentage from ultrasonic sensor
  float ultrasonicPercentage = ((emptyTankDistance - distanceCm) / (emptyTankDistance - fullTankDistance)) * 100.0;
  if (ultrasonicPercentage < emptyTankDistance) ultrasonicPercentage = 0;
  if (ultrasonicPercentage >= fullTankDistance) ultrasonicPercentage = 100;
// Send values to Blynk
  Blynk.virtualWrite(V0, pressureKPa);
  Blynk.virtualWrite(V1, pressureLevelPercentage);
  Blynk.virtualWrite(V2, distanceCm);
  Blynk.virtualWrite(V3, ultrasonicPercentage);
  // Print sensor readings
  Serial.print("Pressure Sensor Voltage: ");
  Serial.print(pressureVoltage, 3);
  Serial.println(" V");
  Serial.print("Pressure: ");
  Serial.print(pressureKPa, 1);
  Serial.println(" KPa");
  Serial.print("Water Level (Pressure Sensor): ");
  Serial.print(pressureLevelPercentage);
  Serial.println(" %");
  //Serial.print("Water Level (Ultrasonic): ");
  //Serial.print(waterLevel);
  //Serial.println(" cm");
   Serial.print("Water Level (distanceCm): ");
  Serial.print(distanceCm);
  Serial.print("Water Level (Ultrasonic Sensor): ");
  Serial.print(ultrasonicPercentage);
  Serial.println();
  delay(5000);  // Adjust delay as needed
icon pressure-sensor-code.zip 1KB Download(0)
2024-11-24 20:00:02
Add decoupling capacitors (e.g., 0.1 µF and 10 µF) near the sensor and ADC power pins to filter noise. Use shielded cables for sensor and ADC connections to reduce electromagnetic interference. Minimize the cable length between the pressure sensor, ADS1115, and Xiao ESP32C6.
You can also make a PCB like this:
 https://www.pcbway.com/project/shareproject/Op_Amp__W__ADS1115.html
userHeadPic lia.ifat
2024-11-21 17:04:18
userHeadPic raza rahil.hussain
2024-11-15 18:36:31
The SEN0237 operates at 5V, so you need to supply 5V to the ADS1115 as well to get an accurate voltage value. This phenomenon is very much like powering the sensor with 3.3V.
Would you able to upload a wiring diagram so we can check if anything is missing?
userHeadPic Yeez_B
raza rahil.hussain wrote:
I've removed the ADS1115 and also put the VCC into 3v3. I"m using Seeed Studio Xiao ESP32C6 Board.
2024-11-21 17:01:35
Yeez_B wrote:
But the sensor could only work under 5V, may I ask where you power the sensor with 5V?
2024-11-25 17:03:23
