Forum >DFRobot_HT1632C
General Arduino
DFRobot_HT1632C
userHead Andrea.Morselli 2024-11-20 23:28:14 377 Views1 Replies
I'm trying to run a test program downloaded from this site:
#include "DFRobot_HT1632C.h"
#define DATA D6
#define CS D2
#define WR D7
//#define RD 7
DFRobot_HT1632C ht1632c = DFRobot_HT1632C(DATA, WR,CS);
char str[] = "Hello";
  // put your setup code here, to run once:
  ht1632c.begin();
  ht1632c.isLedOn(true);
  ht1632c.clearScreen();
    ht1632c.setCursor(0,0);
  ht1632c.print(str);
  // put your main code here, to run repeatedly:
, but I'm continuing to receive always the same error, below:
C:\Users\andrea.morselli\Documents\Arduino\testmatrix\testmatrix.ino:1:10: fatal error: DFRobot_HT1632C.h: No such file or directory
   1 | #include "DFRobot_HT1632C.h"
compilation terminated.
exit status 1
Compilation error: DFRobot_HT1632C.h: No such file or directory
Someone can help me?
2024-11-25 17:53:44
HT1632 library is not the library maintained by DFRobot.
I did not manage to find the library in the repo.
Could you tell me where did you find the sample code?
userHeadPic Yeez_B
