Forum >Turbidity Sensor in oil
General Gravity
userHead Matthew.Bernardi 2024-11-26 00:55:44 811 Views3 Replies
Hi everybody, I wanted to ask if the turbidity sensors (like https://wiki.dfrobot.com/Turbidity_sensor_SKU__SEN0189) can be used to detect oil turbidity (not water)? Does it still work?
2024-12-06 21:47:14
It is designed and calibrated for water. You will not likely get a right result if you immerse it in oil.
userHeadPic lia.ifat
2024-12-06 10:39:58
The sensor uses infrared light to determine how dirty the water is based on the amount of light transmitted. Theoretically, it is also possible to measure the dirtiness of oil, except that the transmittance of light is different between oil and water, so this may lead to inaccurate measurements.
userHeadPic yiqing.guan
2024-11-26 23:18:38
This sensor uses infrared for measurement and cannot be used in soil.
And I think there is no concept of turbidity in the soil.
userHeadPic Yeez_B
