Forum >Walter pH and Conductivity
General Gravity
userHead Gilmar.Oliveira 2024-11-27 01:41:40 837 Views2 Replies
For continuous measurement of swimming poll water pH and Conductivity, by using arduíno based hardware (ESP32), which  sensors are  recommended by you?
I have one Gravity TDS sensor. I would like to know  If It is possible to have by such sensor the measurement of Conductivity of water in micro Siemens/cm, or should i buy another sensor to measure the Conductivity ?
Regards.
Gilmar
2024-11-28 10:39:01
You can use SEN0169-V2 to measure PH and DFR0300 to measure conductivity. And to prevent these two sensors from interfering with each other, it is recommended to use the DFR0504 to isolate the analog signal.
userHeadPic yiqing.guan
Gilmar.Oliveira wrote:
Great. Thank you.
2024-12-07 01:54:35
