Forum >SEN0098-V2 Gravity: Analog Current Sensor 50A (AC/DC) V2
How to selectGravity
userHead Ian.McCutcheon 2024-11-27 11:33:24 1017 Views1 Replies
I am thinking of getting this board and have questions.  There is a rectangle on the end full of via.  Is this connected electrically to either side of the input or output?  If so which.  If not what purpose does it serve as I may need to remove it for my application (and is that a “very bad idea”.)
Thank you.
2024-11-29 13:09:58
If you are asking about the through holes in the red box below, these are GND through holes because the current through the module can be high, so multiple GND through holes will reduce EMI.
userHeadPic Yeez_B
