Forum >SEN0599
SEN0599
userHead androleo09@gmail.com 2024-12-13 18:46:59 1428 Views6 Replies
This sensor is powerful and can work efficiently to what depth?
2024-12-16 10:06:04
Measuring distance: 5-600cm
userHeadPic yiqing.guan
androleo09@gmail.com wrote:
What I mean is that this sensor is strong and efficient up to a water depth of how many meters? because I plan to use this sensor for an ROV or AUV for water exploration at a depth of more than 10 meters, can the sensor still work at that depth?
2024-12-16 11:33:03
2024-12-14 17:27:27
To answer your question accurately about the depth at which "his sensor" can work efficiently, I'll need more details:
Type of Sensor: Is it related to sonar, radar, LiDAR, a pressure sensor, or something else?Application: Is it being used underwater, underground, or in another specific environment?Efficiency Criteria: Are you asking about depth in terms of physical measurement (meters/feet) or operational effectiveness in a particular medium?
If this relates to a product demonstration or technical replay, let me know, and I can provide insights specific to its performance claims or standards.
userHeadPic Waqas.Tech
What I mean is that this sensor SEN0599 is strong and efficient up to a water depth of how many meters? because I plan to use this sensor for an ROV or AUV for water exploration at a depth of more than 10 meters, can the sensor still work at that depth?
2024-12-16 11:33:36
2024-12-13 22:05:36 Measurement Range: 5-600cm. https://wiki.dfrobot.com/Underwater_Ultrasonic_Obstacle_Avoidance_Sensor_6m_SKU_SEN0599?gad_source=1&gclid=Cj0KCQiA0--6BhCBARIsADYqyL_mw1kZisruKCU3uw69qHfxv3O255j3X4Ig1X38nblzE3qVNNcI81UaAlgLEALw_wcB userHeadPic lia.ifat
2024-12-16 11:33:43
