Forum >USB - RS485 Converter - FIT0737
Troubleshooting
userHead anonym 2024-12-14 02:17:04 1836 Views1 Replies
Good afternoon,
I'm writing in this module because I recently bought a USB to RS485 converter to read from an IMD via ModbusRTU.
I know that the USB device in question uses the CH340 driver, which is pre-installed by default on Linux.
I am manually configuring the message sending, following the example provided in the IMD.
So, I send:
Slave ID | Function Code | Data (Registers to read) | CRC
However, even though the TX light turns on, the RX does not.
After some research, I tried adding a start bit "AA" and a stop bit "55". The result was the same.
Previously, I had bought a device that used a CH340 chip, but in that case, it was a USB to CAN converter. It initially required sending a series of commands for configuration.
But for MODBUS RTU, I think this should not be necessary, as sending the packet should be sufficient.
I have confirmed that all parameters match the examples in the datasheet, and they do.
My question is: is there any initial configuration needed for the CH340 chip? Do I need to send any specific bit to activate the chip? Or could the error be with the IMD?
2024-12-16 01:48:07
RS485 communication requires managing the direction of data flow. The USB-to-RS485 converter usually relies on hardware (automatic) or manual control of the RE/DE (Receive Enable/Driver Enable) pins to switch between transmit and receive modes. The CH340-based converter should handle this automatically.
userHeadPic lia.ifat
