Forum >Ask for circuit of Capacitive Soil Moisture Sensor SKU:SEN0193
userHead an.yu.zoey 2018-01-15 09:52:57 2713 Views2 Replies
I'm working on different type of soil moisture sensor, this is one of my research object. I want the actual circuit of this sensor but I searched online there is no official posted circuits of sen0193. Is there anyone know the circuit? and how it actually works? If possible I want the sketch of this circuit.
thanks :D
2018-03-12 05:36:54 You might be interested in this detailed analysis of the SEN0193 sensor schematic. The author concludes that based on that schematic the sensor "will not work". What do you think? userHeadPic dkalischer
2018-01-16 00:34:21 There is no sketch of this sensor, but you can see the schematic from the wiki, and when the moisture changed around the sensor, the capacity would change, and give the signal. userHeadPic robert.chen
