Forum >DFR0063 I2C LCD technical question
userHead Account cancelled 2011-02-25 14:54:58 4321 Views1 Replies
I am using a PC program I created that talks to Arduino via Firmata. The Arduino talks I2C to an EEPROM and the DFR0063.
I know that my I2C stuff is working. I can write to and read from EEPROM. I can turn the LCD backlight on and off at will.
However, I cannot get the LCD to do anything else. I have had it do weird stuff. And I know that when you get it configured to 2-line, both lines will have faint blocks visible (dependent on contrast).
So I am thinking I am missing something. As much as I read the available source code I can't figure it out.
I can see that the LCD interface acts like a shift register, moving 8 bits in and latching them to the LCD pins.
My first question on this topic: what is the order of pins?
I "think" it is: D7 D6 D5 D4 BK E RW RS
Is this correct?
If it is, then I have to dig even deeper and will post follow up question(s).
John
2011-03-01 20:23:03 1) Make sure you uploaded the right library (not the library comes with Arduino IDE. it gives black block)
https://www.dfrobot.com/image/data/DFR0063/Arduino_library.zip
2) There is a contrast adjust potential meter on the back of the LCD unit. Make sure you have played with it.
3) Make sure you have sufficient power and current.
Check this post https://www.dfrobot.com/forum/index.php?topic=63.0
userHeadPic R2D2C3PO
