Forum >Sound sensor DFR0034 V2.2
Hi all,
I have purchased a sound sensor (DFR0034 V2.2, Analog sensor) and i would like to convert the values that the serial monitor show us into DB. Now i m just reading the values of the sensor nothing more.
Information:
Board: Arduino Uno
Sensor : Analog( Output, GND, VCC)
this is my code:
And i would like to convert these values that the sensor measure into decibels :
This what the graph shows me :
this is the link for the datasheet of the sound sensor https://github.com/Arduinolibrary/DFRob ... f?raw=true
Information:
Board: Arduino Uno
this is my code:
int led = 13; int threshold = 100; //Change This int sensor = A0; int valeur ; void setup() { Serial.begin(9600); // For debugging pinMode(led, OUTPUT); //pinMode (sensor, INPUT); } void loop() { valeur = analogRead(sensor); // Reads the value from the Analog PIN A0 Serial.print("Sound Level: "); Serial.println(valeur);//print the value if(valeur>=threshold) { digitalWrite(led, HIGH); //Turn ON Led delay(200); } else { digitalWrite(led, LOW); // Turn OFF Led } delay(100); }
2018-01-20 00:06:12 https://circuitdigest.com/microcontroll ... easurement
I found this project, hope this will helpful
robert.chen
2018-01-19 02:23:13 I have the datasheet of the mic and the datasheet of the sound sensor, i m powering my sound sensor at 5V so I think that should not be complicated to convert it into DB.
alexandre.riasat
2018-01-19 00:19:34 This sensor can only output analog voltage of the sound, the algorithm covert to dB is sophisticated. This sound level meter can output dB directly https://www.dfrobot.com/product-1663.html
robert.chen
