Forum >datasheet and api for TELEMATICS 3.5" TFT TOUCH LCD SHIELD SKU: DFR0387
Can you provide a link to the TELEMATICS 3.5" TFT TOUCH LCD SHIELD SKU: DFR0387 datasheet with the coding api
How do you use the 3 available Serial ports?
2018-01-19 00:50:16 You can just connect the screen to your main board by TX/RX or I2C, and then the code in the wiki is available to use, since this is a screen doesn't need any driver.
robert.chen
