Forum >Problem with uploading sketch to Arduino
LattePandaGeneral
userHead Account cancelled 2018-02-01 13:14:36 2862 Views0 Replies
I have a LattePanda 4G and I am trying to upload a new sketch to the Arduino but the com port keeps dropping out on me.. I have done the reset Arduino trick but the com port(COM5) never returns unless I restart Windows..
The Com port is dropping right when the upload starts.. Below is the error msg..
Arduino: 1.8.5 (Windows 10), Board: "Arduino Leonardo"
Archiving built core (caching) in: C:\Users\NAME\AppData\Local\Temp\arduino_cache_826180\core\core_arduino_avr_leonardo_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 3618 bytes (12%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes (5%) of dynamic memory, leaving 2411 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM5
PORTS {COM1, COM5, } / {COM1, } => {}
PORTS {COM1, } / {COM1, } => {}
Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
