Forum >DFR0009 A1 and Gravity UV Sensor
userHead contact 2018-02-05 15:22:26 2071 Views3 Replies
When i conecte the gravity UV Sensor on the DFR0009 shield the result is wrong, if i connect whithout the shield or on A5 its ok, i know the A0 is occuped but the A1.. do you know what ?
Best reagrds
2018-02-09 23:32:36 Hi,
Did you connect to the right pin? A0 is not on the shield
userHeadPic robert.chen
2018-02-06 00:48:03 A5 is the "Analog In 5" on the shield DFR0009 (DFRobot LCD keypad shield v1.1)
Best regards
userHeadPic contact
2018-02-05 23:15:52 This LED shield should display when connect it on Arduino and upload the code, What do you mean using A5? userHeadPic robert.chen
