Forum >Bluno Nano Problems (Reading its characteristics & Resetting its factory services)
Bluno General Arduino
userHead info 2018-02-06 14:09:45 1461 Views0 Replies
ok I have 2 bluno nanos, each with a different problem:
1. Bluno Nano v1.9: I had it working with a sketch where I could send string data from a BLE iphone application (BlueCap, LightBlue, BlueScanner, BlunoTerminal and I could see the data received on the bluno side by viewing it on the Arduino IDE Serial Monitor. While messing with different sketches, all of a sudden this bluno lost one of its 2 factory services. I dont know which one, but I know that it only broadcasts 1 service now and I can no longer connect to the bluno with any app or even with my computer. I used to be able to connect with the bluno app over bluetooth and see both services and read/write to them, but not any more. Originally the board was v1.8, I even tried upgrading it to v1.9 but factory services were not restored.
QUESTION #1: Can it be fixed and how?
ANSWERED: 2 days without plugging it in and its back to normal! YEAY!
2. Bluno Nano v1.8: I just got this other Bluno working with the simple sketch for receiving from the BlunoTerminal iOS app:
Serial.begin(115200); //initial the Serial
if (Serial.available()) {
Serial.write(Serial.read());//send what has been received
Serial.println(); //print line feed character
It works perfectly!
As for sending data, Im confused how it works. This works perfectly, I can see the value in my BlunoTerminal or even the DFRobot iOS BlunoTestDemo app:
void setup(){
Serial.begin(38400);
void loop(){
delay(3000);
sendOverBLE();
void sendOverBLE() {
Serial.write("59");//send what has been received
And it sends the data from bluno to BlunoTerminal iOS app. But when I send the number 59, which is what I want because I need to send numeric data to the phone, I get a ; which is the ascii representation of the number 59. So how do I send numeric values?
If I understand correctly, I can get the data from my bluno on my ble device in 2 different ways: (a) reading serial data written from the bluno to the iOS app BlunoTerminal {which is what I did in the above sketch with "59"} and (b) reading the dfb0 characteristic value from any iOS ble app like BlueCap or LightBlue and see what the sent value is.
Please explain 2 things:
QUESTION #2: Can I take a value in my bluno sketch and put it into its dfb0 ble characteristic and have the ios ble LightBlue/BlueCap read it? how?
QUESTION #3: If the above cannot be done, or even if the above is an option, how do I make the other option? How do I send the numeric vlaue of 59 to the ios BlunoTerminal app?
ADDITIONALLY
I noticed that sometimes when I run the sketch that sends 59 from the bluno to the iOS BlunoTerminal app, sometimes the app gets (null). And it is not until I open the Arduino IDE Serial Monitor that it begins to send the correct data instead of null.
QUESTION #4: Why does this happen?
