Forum >Linux compatibility.
Bluno General Arduino
userHead Account cancelled 2018-02-08 10:11:23 1116 Views0 Replies
I see a few unanswered questions in the forums relating to this.
1. No tty is created upon connection via usb. A normal arduino created ttyASM0 usually.
Recommendation is to flash firmware.
2. No mention of a linux flash utility. Only win/mac. Is this correct or did I dfrobot something?
EDIT:
Also unable to use FDTI. I've tried a few different ones all known working and I get nada. Tried entering AT mode, no reply. FTDI setup is tx/rx pads with leads soldered on to usb adapter.
Bruce
