Forum >Receiving only 0s for SEN0177
userHead jack.scherlag 2018-02-08 17:04:43 7298 Views11 Replies
I am using an Arduino Uno that is connected to a PM2.5 adaptor that is connected to the PM sensor. I have tried using software serial and hardware serial, but the serial monitor still reads 0 on PM1.0, 2.5, and 10.
2019-10-01 18:46:41 i'm using a separate power supply for the adaptor board/SEN0177
it is set for 5V and it seems to cycle thru a current consumption of 50 -70mA
what else do you need me to check ?
thanks for your time
userHeadPic anonymous
2019-09-29 19:25:16 Hi,
i have the PM2.5 adapter V2.0 board connected to the SEN0177.
i use software serial (RX: 10, TX: 11)
code is V3.1, march 25 2016
2019-09-28 23:49:25 can you tell what you did to get it to run?
i have the same problem using the SEN0177 and an arduino UNO, all i get from the sensor is 0's
tried another board, checked connections again and again etc ...
but nothing works it only returns 0's
2018-02-10 10:23:57 After playing around more with the software serial code, I was able to get the device to start reading properly. userHeadPic jack.scherlag
te20.shol wrote:
how? can u explain it? i m facing same problem right now.
2024-03-04 02:26:31
2018-02-09 23:39:49 If you use hardware serial, how do you display the reading, you can't use serial monitor to display the outputs. userHeadPic robert.chen
2018-02-09 10:12:28 In the picture, I am using hardware serial userHeadPic jack.scherlag
2018-02-09 01:24:01 How do you connect the sensor? can you show a picture of the wiring? userHeadPic robert.chen
2018-02-08 17:04:43 I am using an Arduino Uno that is connected to a PM2.5 adaptor that is connected to the PM sensor. I have tried using software serial and hardware serial, but the serial monitor still reads 0 on PM1.0, 2.5, and 10. userHeadPic jack.scherlag
