Forum >Is there a way to reset the Arduino from code?
LattePandaGeneral
userHead Account cancelled 2018-02-15 08:41:06 1753 Views0 Replies
I posted this on the LattePanda forums too, but have received only one reply that was rather 'meh' in its enthusiasm.
So I thought I'd try here.
On the LattePanda is there a way to reset the Arduino via code instead of having to use the physical switch?
For some reason the Arduino Leonardo does not show up in Device Manager after a restart unless that reset button is pressed.
I'm concerned because this device is going to go in a case and then put somewhere not easily accessible. I need the LP to be able to communicate reliably to the onboard Arduino after a restart.
If we can reset it via code once after reboot that would solve my immediate problem.
Thank you,
