Forum >Humidity and Temperature Sensor analog output
Hello!
Do you have Humidity and Temperature Sensor with analog output 0 - 5 V
or
I2C to analog converter ?
or
2019-03-23 19:23:46 There are several of them, indeed. If the process of measuring of humidity starts, you can simply check several of them here.
liprofilewriter
2018-03-04 03:25:02 With the passage of the time we saw that our scientist are finding some new things for us. Which also giving us the news on https://www.myassignmentwriting.com.au/dfrobot/ about the humidity and temperature. Which is new for our leaning material and also for help us in our work.
chgzmwfxg
2018-03-03 06:18:11 Yes, you can search on the website, there are lots of humidity and temperature sensor https://www.dfrobot.com/search-humidity.html
robert.chen
