Forum >Dfrobot SPI LCD Module R9 and R10
userHead house91320 2011-09-18 16:29:15 4608 Views3 Replies
Do I need to switch R9 to R10 because that under the black pcb>
2011-09-22 18:29:29 Hi House,
Maybe I did not understand your question. But here is a quote from the Wiki:
"Mode Selection
The LCD is shipped in Pallelel mode in default. The R9 is used to set the interface mode. To switch to SPI mode, the R9 resistor need to be moved to R10."
In any case, I'm glad you figured it out.
Hector
userHeadPic Hector
2011-09-22 16:11:52 The wiki lacks the info but i figured it out. userHeadPic house91320
2011-09-19 18:24:19 Hi House,
Have you seen the product wiki? It explains the operation of the LCD shield. If you have more questions please let me know.
[URL=https://www.dfrobot.com/wiki/index.php?title=SPI_LCD_Module_(SKU:DFR0091)]LCD WIKI[/URL]
Hector
userHeadPic Hector
