Forum >Fez Domino, setting the Bluetooth Bee baud rate
userHead Soth1985 2011-11-06 16:45:14 4648 Views3 Replies
Hello, I`ve recently purchased a BluetoothBee from http://www.dfrobot.com/index.php?route=product/product&path=45&product_id=193. It`s default baud rate is 9600 bps and if I want to change it I have to put the module into AT mode and execute some AT commands as stated in http://www.dfrobot.com/wiki/index.php?title=BLUETOOH_BEE_(SKU:TEL0023). I`ve tried connecting to the bee with a terminal program and entering AT -> AT+BAUD8 and also tried to write these command directly to the COM1 port on the device using SerialPort class, but both these approaches failed.
What am I doing wrong and is it possibe to reconfigure the bluetooth bee using Fez Domino? The bluetooth module is working and I`m able to send and receive data on the Domino but only if it`s SerialPort is created with 9600bps.
2011-11-11 19:42:31 [quote]
Ok, You can use the Arduino serial terminal. The default "AT Mode" baud rate is 38400 and you need to set "both NL & CR" setting next to the baud rate. Now you should be able to make the necessary changes. If the first time you try it returns an "error(0)" just try again.
[/quote]
Did you try the 38400 Baud rate? Did you try it from the Arduino terminal? I couldn't get Putty to work for some reason.
userHeadPic Hector
2011-11-11 15:49:03 I`m using putty. Yes I use the switch to set the AT mode, on the Bluetooth Bee the green light turns on when I connect to it with putty through the virtual COM port, which was created by Windows for the Bluetooth_V3 device. I send AT command but get nothing in response from the device. userHeadPic Soth1985
2011-11-08 18:45:44 Hi Soth,
How are you connecting the bee to your PC? Are you using a USB xbee converter?
What terminal program are you using?
You are placing the on-board switch to AT mode, yes?
I'm not sure if you can program it from your FEZ.
userHeadPic Hector
