Forum >X-Board: possible to use ethernet and serial (via FTDI basic) at the same time??
userHead manufwi 2011-11-24 03:02:26 3286 Views1 Replies
I just bought an X-Board (quick shipping BTW!) and I have a problem: I tried the chat server sketch and it works great but when I add a serial communication the server does not respond anymore. So is it possible to do both at the same time?
Also is it possible to use ethernet and xbee at the same time?
And, last question, how is it possible to setup the xbee module using only the x-board?
TIA
2011-11-24 11:03:44 OK sorry it works, but just in case for others who will run into that you need to do:
server.begin();
delay(1000);
Serial.begin(9600);
It seems that the delay is necessary, perhaps 1 sec is too long, but a delay is needed.
HTH
userHeadPic manufwi
