Forum >liquidCrystal_I2C and arduino RC2 IDE = error
userHead mrbbp 2011-11-03 15:06:12 15079 Views6 Replies
Hello, i've recently bougth the 16x2 I2CLCD (DFR0063)and tried it on my arduino.
i need some time to find the good pins for SCL and SDA... ANALOG PIN 4 & 5... so...
I work with Arduino RC2 IDE and enable to compile the "hello world" sketch's.
there is an error on line 81 from lib about a bad return...
[quote]In file included from jeanLoup_Lcd.cpp:3:
/Applications/Arduino rc2.app/Contents/Resources/Java/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:81: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::write(uint8_t)'
/Applications/Arduino rc2.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
[/quote]
I've tried with Arduino021 and it's fine and great lib but...
Do you plan to correct the problem for the new IDE?
Best regards.
2012-03-01 00:45:05 I´ve got dedicated support from EXP tech ([url=http://www.exp-tech.de]http://www.exp-tech.de[/url]). Now I worked with the Arduino-Software 0023 and the sketch runs without any problems.  :)
Helge
userHeadPic 12Haegar34
2012-02-29 02:01:35 Hello, for my situation the bug in the library still exists.  :(  I like to connect the LCD-Display, type "DFRobot I2C/TWI LCD 1602", with my Arduino ATmega 168 at IC2. I´ve loaded the library from this link [url=https://www.dfrobot.com/index.php?route=product/product&keyword=DFR0063&category_id=0&description=1&model=1&product_id=135]https://www.dfrobot.com/index.php?route=product/product&keyword=DFR0063&category_id=0&description=1&model=1&product_id=135[/url] . And I tried also the library from Erik Bartmann and from this link [url=http://arduino-info.wikispaces.com/file/view/Arduino_library.zip]http://arduino-info.wikispaces.com/file/view/Arduino_library.zip[/url] .
But always: After verifiying the example "Hello world", I´ll get the error-message: "In file included from HelloWorld.cpp:5:
C:\ARDUINO\Arduino ATmega128\Development environment\Windows\arduino-0018\libraries\neu/LiquidCrystal_I2C.h:81: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::write(uint8_t)'
C:\ARDUINO\Arduino ATmega128\Development environment\Windows\arduino-0018\hardware\arduino\cores\arduino/Print.h:48: error:  overriding 'virtual size_t Print::write(uint8_t)' ".
The little program, I want to use, is this:
//DFRobot.com
//Compatible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
  lcd.init();                      // initialize the lcd
  // Print a message to the LCD.
  lcd.backlight();
  lcd.print("Hello, world!");
Please, can somebody help me?
2011-12-06 23:21:02 Yes, a really cool news. 8) userHeadPic mrbbp
2011-12-06 19:05:51 Hi Roberto,
Thanks for your follow up and patients. There is good news. We have an updated library. Thanks to one of our customers :
Erik Bartmann
[url=http://www.erik-bartmann.de/]www.erik-bartmann.de[/url]
You can download the updated library from the [url=https://www.dfrobot.com/index.php?route=product/product&filter_name=DFR0063&product_id=135]product page[/url]
userHeadPic Hector
2011-12-05 08:22:20 Are there (good) news about the bug fixing?
I would like to use the 1.0 Arduino IDE ...
Roberto
userHeadPic BRUNIALTI
2011-11-03 21:37:26 Hi Mrbbp,
We are aware of the issue, and we will try to fix it, but I'm not sure when the update will be released.
userHeadPic Hector
