Forum >Raspberry Pi Arduino programming over GPIO
userHead Account cancelled 2018-04-08 22:25:27 2890 Views0 Replies
Might it be possible to plan the Arduino? Do I need to configure avrdude with this and what's the communication pins utilized? Your tutorial for programming the protect only comprises installation of VNC server, and that I presume you've got the shield attached to USB because I can't get it to app within the RP uart. I really don't have an error, but programming seems to finish, but no action on the board and application isn't written.
You will find several write ups about configuring arduino programming within GPIO for additional version apparatus, if you do not possess the info available is another device I will use similar configurations for?
