Forum >Sunflower: Solar Power Manager 9V/12V/18V
Easy IoT General
userHead Account cancelled 2018-05-15 05:13:01 2918 Views1 Replies
Can I charge 3.7v Li-ion battery using solar power manager?
Because in the diagram it is shown Li-ion battery as an input but in the specification said like input should be of the range 7-30V.
Little confusing
Does this circuit charge li-ion battery along with 3 outputs?
Regards,
Chandan
My understanding about this solar power manager is
When solar panel having DC output of 7-30v is connected, It can charge Li-ion battery(2600 mAh) as well as gives regulated output of 3.3v, 5v, 9/12v.
So when there is no solar input does it does the circuit take input from Li-ion battery and give regulated 3.3v and 5v outputs?
Regards,
Chandan
2018-05-15 22:40:51 Yes, you can do that, just put the MPPT switch to OFF, the wiki gives more detail about the function https://www.dfrobot.com/product-1714.html userHeadPic robert.chen
