Forum >Dust Sensor Mode Setting
userHead Rei Vilo 2018-06-06 04:03:22 9800 Views7 Replies
The Dust Sensor works fine with the example provided.
However, the wiki page is mhmm about how to use the SET mode setting pin.
  • - Could you please elaborate about the SET mode setting pin?
The PM2.5 sensor adapter board provide two pins for a jumper. I'd like to put the sensor to sleep and thus low power mode and wake-up only before I perform a reading.
  • - Is there a way to drive the SET pin with a GPIO from the MCU?
Similarly, I couldn't find the schematics of the PM2.5 sensor adapter board.
  • - Are the schematics of the PM2.5 sensor adapter board available, and where?
Thank you!
2020-01-18 04:49:44 Can you please share the schematic again. Thank you in advance. userHeadPic h.aykanat
2018-11-23 11:46:36 Thank you for posting the schematics in PDF format for the SEN0177 Sensor Adapter.
I was able to figure out how to control the SET/SLEEP pin with an ElectricImp.
userHeadPic gxbene
2018-06-07 23:14:49 Thank you very much! userHeadPic Rei Vilo
2018-06-07 19:29:49 Here is the pdf file. userHeadPic robert.chen
2018-06-06 22:52:34 Thank you for the explanations and the schematics.
Could you please provide the picture with a higher definition or even better, as a PDF? Thank you!
2018-06-06 22:35:51 1. The SET pin gives the mode change of sleep mode, which will make it keep working if give SET a high level signal, and would in sleep mode if give it low level signal
2. please check the attachment about the schematic.
