Raspberry Pi 4B Starter Kit
$76.70
  • RAM
    2GB4GB8GB
  • Power Supply
    US StandardEU Standard
  • Aluminum Case
    Aluminum Case for RasCost-effective Case with Heatsink & Fanpberry Pi 4 (with Heatsink & Fan)Cooling-effective Case with Dual Fans
  • HDMI
    Mini HDMI to Micro HDMIHDMI to Micro HDMI
  • SD Card
    32GB64GB128GB
  • Add-on
    0.3 MegaPixels USB Camera5" 800x480 DSI Touchscreen7” 800x480 DSI Touchscreen
  • Quantity
  • Introduction
    Get everything you need to unleash the full potential of your Raspberry Pi 4! This comprehensive kit includes a Raspberry Pi 4 Model B board (available in 2GB, 4GB, or 8GB variants), a high-quality USB power supply, a durable aluminum case with excellent cooling performance, a 4K Micro HDMI cable, and a reliable MicroSD memory card. Perfect for beginners and advanced makers alike—just Plug & Play to get started.
    Raspberry Pi 4 Model B (2GB / 4GB / 8GB)
    Equipped with a high-performance 64-bit quad-core processor, the Raspberry Pi 4B is ideal for projects requiring speed and versatility. Key features include:
  • Dual-display support up to 4K resolution via micro-HDMI ports.
  • Dual-band 2.4/5.0 GHz wireless LAN and Bluetooth 5.0.
  • Gigabit Ethernet and USB 3.0 for ultra-fast data transfer.
  • Hardware video decoding up to 4Kp60 for smooth media playback.
  • PoE capability (requires a PoE HAT add-on).
  • Raspberry Pi 4 Model B SBC
    4K HDMI / Mini HDMI to Micro HDMI Cable
    This micro-HDMI cable is designed specifically for the Raspberry Pi 4B, offering:
  • 4K HD Resolution: Stable and precise video transmission.
  • Broad Compatibility: Works with laptops, HDTVs, tablets, and projectors.
  • Plug & Play: No delay, no flashing—just seamless performance.
  • 4K Micro HDMI Cable
    5V@3A USB Power Supply (US Standard / EU Standard)
    This reliable power adapter ensures optimal performance for your Raspberry Pi 4:
  • Stable Power Output: 5V@3A for consistent operation.
  • Certified Quality: Meets UL safety standards with over-current protection.
  • Convenient Design: Includes a Type-C cable to match the Raspberry Pi 4’s power interface.
  • 5V@3A USB Power Supply
    Case
    Why Choose Our Case?
    We've selected 2 high-quality aluminum cases with a powerful cooling effect in the kit.
    Our Aluminum Alloy Case:
    The aluminum alloy material is hard; easy to install.; double cooling effect with fan & heatsink; delicate appearance; not easy to rust.
    Other Acrylic Case:
    The plastic material is thin and fragile. The Acrylic case is hard to assemble. The fan is at a lower speed and hard to cool. The fan is easy to make a lot of noise; Easy oxidized and looks ugly.
    Raspberry Pi 4B Case
    How to Choose the Case?
    If you are looking for value for money, we recommend you choose the Aluminum Case for Raspberry Pi 4 (with Heatsink & Fan), it is perfect for novices.
    If you want a better look and a better cooling effect, we recommend you choose the metal case for the Raspberry Pi 4B (Dual fans). This case can improve your user experience.
    This aluminum-made case features a hollow design, delicate appearance, and high hardness. The aluminum material makes it not easy to rust and more conducive to heat dissipation.
    Metal Case for Raspberry Pi 4B (Dual fans)
    With Cut-out Design Simple and Aesthetic; Open design, avoid signal isolation, no influence on Wi-Fi, and Bluetooth; Dual fans, advance the cooling efficiency.
    How to Choose the Raspberry Pi 4B Case
    Sandisk MicroSD Memory Card (32GB / 64GB / 128GB)
    This high-speed memory card is perfect for running your Raspberry Pi:
  • Reliable Performance: Up to 98 MB/s read speed, waterproof, temperature-proof, magnet-proof, and X-ray-proof.
  • Versatile Usage: Compatible with other devices such as smartphones and tablets.
  • Convenient Adapter: Includes an SD adapter for wider compatibility.
  • Sandisk MicroSD Memory Card
    Optional Add-Ons
    DSI Touchscreen Displays (5" / 7")
    High-resolution capacitive touchscreens that support Raspberry Pi DSI interface:
  • 5 or 7 Inches: Choose the size that best fits your project.
  • Integrated Design: Mount your Raspberry Pi directly on the back.
  • Backlight Adjustment: Hardware-based backlight control for convenience.
  • Raspberry Pi 4 Display
    0.3MP USB Camera
    A compact and driver-free USB camera for Raspberry Pi and NVIDIA Jetson Nano:
  • 640x480 Resolution: Suitable for image recognition, security, and teaching.
  • Compact Size: Easily fits into embedded systems.
  • Plug & Play: No drivers required, hassle-free setup.
  • 0.3MP USB Camera
  • Raspberry Pi 4 Model B Board (2GB/4GB/8GB) x1
  • 5V@3A USB Power Supply (US/EU Standard) x1
  • 4K Micro HDMI Cable x1
  • Aluminum Case (with Heatsink & Fan) x1
  • MicroSD Memory Card (16GB/32GB/64GB/128GB) x1
    Optional Accessories:
  • Metal Case (Dual Fans)
  • DSI Touchscreens (5"/7")
  • 0.3MP USB Camera
  • Raspberry Pi 4B Starter Kit
    $76.70
