URM06 - Narrow Beam Ultrasonic Distance Sensor (20~1000cm, PULSE)
$45.00
SKU: SEN0151
  • $44.00 2+ items
  • $43.00 5+ items
  • $42.00 10+ items
Purchase this product and earn 450 reward points, which are tied to VIP membership program. Learn More >
Ultrasonic sensors emit ultrasonic pulses, and by measuring the time of ultrasonic pulse reaches the object and back to the transducer, the distance of sensor from the target object is calculated. They are widely used in detecting displacement, thickness, distance, water level, material level and transparent objects.
The URM06 - PULSE Ultrasonic sensor provides very short to long-range detection and ranging from 20cm ~ 10m, comes in a compact, robust PVC housing and matches 35mm electrical pipe mounting. It comes with TTL pulse interface and works at high output acoustic power. The ultrasonic sensor detects objects from 20cm to 1000cm and provides range information with 1cm resolution. The URM06 has 15 degree beam angle which has excellent receive sensitivity.  And it works best when detecting soft targets. The similar sensors are widely used in professional mobile robot systems such as Pioneer robots.
The URM06 series sensors are the best ultrasonic sensor available in the market regarding its beam angle, senstivity and accuracy.
URM06 Beam Angle
URM06 Beam Angle
If you need want to learn more about ultrasonic sensors, please click here to check DFRobot Ultrasonic Sensor Selection Guide.
  • robot navigation
  • obstacle avoidance
  • measuring distance devices
  • engineering measurement tools
  • industrial control system
  • Working Voltage: 6V-12V (5V is acceptable but not recommended)
  • Rated Current: 16mA
  • Peek Current: 2A
  • Interface: TTL pulse
  • Working Frequency: 49.5KHZ
  • Working Temperature: -10℃ ~ +70℃
  • Beam Angle: 15°(-6dB)
  • Detecting Range: 20cm ~ 10m(7.87"~393.70")
  • Size: 50mm(1.97")(diameter)*43mm(1.69")((length)
  • Mounting Thread Diameter: 35mm(1.38")
  • Weight: 50g
  • URM06-PULSE Ultrasonic          x1
DFRobot URM Ultrasonic Distance Sensor Selection Guide
Blog DFRobot URM Ultrasonic Distance Sensor Selection Guide
Apr 08, 2020
DFRobot URM Ultrasonic Sensors:  High-Performance and Diverse Selection
Blog DFRobot URM Ultrasonic Sensors: High-Performance and Diverse Selection
Aug 15, 2023
