Gravity: Analog ORP Sensor Meter for Arduino
$89.00
SKU: SEN0165
  • $87.00 3+ items
  • $85.00 5+ items
  • $83.00 10+ items
Purchase this product and earn 890 reward points, which are tied to VIP membership program. Learn More >
In the ever-increasing need and awareness for health and safety, water has become a focus point for proper disinfection treatment as aftereffects of industrialization can become a danger for contamination of water via direct contact. Water is a critical control point of contact where proper treatment can greatly reduce these microbes, thereby reducing the chances of illness and pollution.
While traditional ORP meters are hard to get or use, this Analog ORP Meter is a highly compact ORP monitoring system that fits into your Arduino. This design configuration allows the user to accurately monitor ORP without having to add any additional circuitry or components to your design. Communication with the Analog ORP Meter is done using only simple wiring and programming. You may also check Liquid Sensor Selection Guide to get better familiar with our liquid sensor series.
ORP (Oxidation-Reduction Potential) is a measure of the ability of oxidation and reduction of the aqueous solution, characterization of oxidizing or reducing the relative degree. Unlike a pH measurement that follows a logarithmic curve and therefore requires more calibration adjustments, ORP follows a linear relationship and does not need instrument adjustment as much as it needs electrode maintenance. ORP has proven to be a reliable method of measuring water quality and provides the operator with a single value of measurement regardless of which product, commodity, operation, treatment, or sanitizer is used, and regardless of varying field conditions or methods by which chemical is applied.
Attention:
The bottle cap of the probe contains protective liquid (3.3mol/L KCL). Even if the bottle cap is screwed tightly, some protective liquid may still leak around the bottle cap, forming white crystals. But as long as there is still protective liquid in the bottle cap, it will not affect the life and accuracy of the probe. So please use it with confidence. It is recommended that the white crystals be poured back into the protective liquid in the bottle cap.
  • Water Quality Testing
  • Aquaculture
  • Marine Science
  • Hydroponic Gardening
  • General Chemistry
  • Module Power:+5.00V
  • Module Size: 40mmX27mm(1.57"x1.06")
  • Measuring Range:-2000mV—2000mV
  • Suitable Temperature:5-70℃
  • Accuracy:±10mv (25 ℃)
  • Response Time:≤20sec
  • ORP Probe with BNC Connector
  • PH2.0 Interface(3 foot patch)
  • Zero calibration button
  • Power Indicator LED
  • ORP probe (BNC connector) x1
  • ORP probe circuit board x1
  • Analog cable x1
Dec 28, 2019
May 18, 2022
ORP Water Quality Detector Creating Data Charts in Google Sheets w/ SIM808
Projects ORP Water Quality Detector Creating Data Charts in Google Sheets w/ SIM808
Kutluhan Aktar
Nov 17, 2022
GSM & SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Projects GSM & SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Kutluhan Aktar
Mar 31, 2022
Sven.Sven Jan 08, 2025
Chih.Kuo Dec 03, 2020
great!
