Bluno Bee - Turn Arduino to a Bluetooth 4.0 (BLE) Ready Board
$9.90
SKU: TEL0073
  • $9.50 3+ items
  • $8.90 5+ items
  • $8.40 10+ items
Bluno Bee is a serial to bluetooth 4.0 module, it adopts XBEE form factor which is compact and is compatible with all shields with XBEE socket.  Bluno Bee is designed to have voltage regulator which supports both 5V and 3.3V MCUs.
Bluno Bee is talking to your Arduino serial port , and able to turn your arduino to bluetooth 4.0 (BLE) ready instantly.  Simply get an Arduino IO Sensor Expansion Shield and plug this module to xbee socket, you have an Arduino BLE ready board.
With two Bluno Bee, two arduino are able to communicate with each other via Bluetooth.  You can enjoy features like point-to-point wireless transparent transmission, master-slave machine setting, wireless code (sketch) uploading and HID connection with PC.
For more compact size or want an all in one arduino ble board, we recommend our Bluno series,  they are based on Arduino Uno or Arduino Mega and with Bluetooth 4.0 (BLE) build-in, they are more cost effective and compact.
We've also developed Apps (Play Bluno) on both Android and IOS platform for you to start playing between phone and arduino immediately. At the same time, we provide developers more freedom and support: users can not only debug Bluno - An Arduino Bluetooth 4.0 (BLE) Board through AT command, but also update BLE chip firmare via USB.
It is suitable for applications like wearable device, for example a smart pedometer bracelet with Arduino + Android/IOS. By linking into star network of low power consumption, BLE achieves rapid real-time communication.
JavaScript display
Product Name Bluno Bee - Turn Arduino to a Bluetooth 4.0 (BLE) Ready Board
Bluetooth 2.0 Module V3 For Arduino
Bluetooth 2.0 Bee Module For Arduino
Bluno Link - A USB Bluetooth 4.0 (BLE) Dongle
Bluetooth Adapter Mini
SKU TEL0073
TEL0026
TEL0023
TEL0087
TEL0002
BLE Chip
 TI CC2540
CSR BC417143
CSR BC417143
 TI CC2540
Frequency
2.4GHz
2.4 ~ 2.48GHz unlicensed ISM band
2.4GHz
2.4 ~ 2.48GHz FHSS
Transfer rate
1Mbps GFSK
Asynchronous: 2.1Mbps (Max) / 160 kbps; Synchronous: 1Mbps/1Mbps
1Mbps GFSK
3Mbps
BLE protocol
V4.0
V2.0 + EDR
V2.0 + EDR
V4.0
V2.0
Modulation
GFSK
GFSK
GFSK
GFSK
FHSS
Power consumption
10.6mA average, ready mode: 8.7mA
Sensitivity
-93dBm
≤-84dBm
≤-84dBm
-93dBm
≤-84dBm
Working Voltage 3.3V
+3.5 V ~ +8 V DC and 3.3V DC/50mA
3.3V
3.3V
Operating temperature
 -40 ℃ ~ +85 ℃
-20 ℃ ~ +55 ℃
-20 ℃ ~ +55 ℃
-10 ℃ ~ +85 ℃
-20℃ ~ +55℃
Transmission distance
30m
20 ~ 30m
20 ~ 30m
10 ~ 20m
<10m
Dimension
32*22mm
40*20*13mm
32*24*9mm
32mm * 16mm
20*16*8mm
Weight (g)
10
10
12
10
10
AT command to debug the BLE
master-salve machine switch
Transparent transmission
Wireless programming
√ (Available for Bluno series)
iBeacons
BLE HID
Mobile App Control
Key Featuressupport Android and IOS applications,open source code,suitable for secondary development by the user
Compatible with APC220 communication interface, can be directly used in I/O Expansion Shield, Romeo, XBoard and etc,.
It can be plugged into the Arduino controller using the XBEE base for Bluetooth wireless control.
Standard USB interface. Support for firmware update via USB. Install Arduino UNO USB driver, default host mode.
USB2.0 standard interface. supports the native Windows Bluetooth stack.
  • AT command to debug the BLE
  • support the master-salve machine switch
  • Transparent transmission
  • Wireless programming for Arduino processor (Compatible with Arduino UNO,Fio and Mega)
  • support usb update BLE chip program
  • support bluetooth HID
  • convenient to upgrade firmware of BLE
  • support Android and IOS applications,open source code,suitable for secondary development by the user
  • Chip:TI CC2540>
  • Working Voltage: +3.3 -5v DC
  • Power consumption: working: 10.6mA average, ready mode: 8.7mA
  • Pin Layout: Compatible with Xbee pinout
  • Frequency: 2.4GHz
  • Transfer rate:  ≤1Mbps
  • Modulation: GFSK, bluetooth low power, V4.0
  • Sensitivity: -93dB
  • Operating temperature: -40 ℃ ~ +85 ℃
  • Transmission distance: 60m in free space
  • Size:32mm * 22mm (1.26 * 0.87")
  • Bluno Bee  x1
$34.90
